PERFORMANCES
STANDARDS ACEA A1 / B1
API PERFORMANCE SN
SPECIFICATIONS
FORD WSS M2C 948 B
(Compatible 913 A, 913 B, 913 C, 925 A & 925 B)
JAGUAR LAND ROVER – STJLR.03.5004
This 100% Synthetic engine oil is formulated to lubricate perfectly the latest generation of FORD
Gasoline engines, except Ford Ka 2009 (08/2008) requiring 917 A, Ford Focus ST 2.5L Duratec
(2004) requiring 913 D, Ford Focus RS (2004) requiring 937 A, and also 1.3L, 1.6L and 1.8L Duratec
engines requiring 913 D.
The specification FORD WSS M2C 948 B is especially required for the 1.0L EcoBoost 3-cylinder AR15firing
Gasoline engines, but it is also fully compatible with the other FORD Gasoline engines, apart from
exceptions. Therefore specification FORD WSS M2C 948 B covers most Gasoline engines currently
requiring specifications FORD WSS M2C 913 A, 913 B, 913 C, or 925 A, 925 B as for JAGUAR and
LAND ROVER.
For these JAGUAR and LAND ROVER engines requiring previously FORD WSS M2C 925A or 925B
standards, the specification STJLR.03.5004 now applies as a replacement. STJLR.03.5004 covers
most of JAGUAR LAND ROVER Gasoline engines except for V6 and V8 supercharged.
Associated with ACEA A1/B1 an API SN standards for lubricants, MOTUL SPECIFIC 948 B 5W-20
provides significant energy savings (>3.3%) while maintaining, and even exceeding in some cases,
robustness requirements of 913 C. This improved
fuel economy and low emissions performance meet
these OEMs requirements for CO
emissions reductions.
MOTUL SPECIFIC 948 B 5W-20 delivers outstanding oil f
ilm resistance, while facilitating cold start,
reducing friction in the engine, maintaining the oil pressure and lowering engine operating
temperatures.
Through its exceptional lubricating properties, MOTU
L SPECIFIC 948 B 5W-20 provides high level of
wear resistance, high temperature resistance and oxidation resistance. It reduces the formation of
deposits, reduces wear and enables perfect control of oil consumption.
Anti-wear, Anti-corrosion, Anti-foam properties.
Απο το ως ανω δελτιο προδιαγραφων της εταιρειας για το 5-20 προκυπτει οτι ο κινητηρας του
fiesta st ΠΟΥ ΕΙΝΑΙ 1,6 DURATEC αν δεν κανω λαθος ,παιρνει το 5w-30 λαδι.
Εν προκειμενω τα χιλιαρακια ΚΑΙ ΜΟΝΟ αυτα παιρνουν το 5w-20
Αρα η παρατηρηση του φιλου ειναι πολυ σωστη.
