- #1
Body
Bodystyle Hatchback
Doors 3,5
Seating capacity 5
Powertrain
Type of engine In-line
Cylinders 4
Engine installation Front mounted engine, transversee
Cubic capacity 1242 cm³
75 cu.in.
Max. power output 60 kW
82 PS
~ 80 hp
@ 5800 rpm
Bore x Stroke 71.9 x 76.5 mm
Compression ratio 11.0:1
Valves per cylinder 4
Valvetrain Over-Head Cam (OHC)
Fuel injection Multipoint injection
Charger None
Max. Torque
114 Nm
84 lbs ft
@ 4200 rpm
Drivetrain serial Front wheel drive
Manual gearbox 5
Automatic transmission None
Displacement-to-power
ratio
48.3 kW/l
66.0 PS/l
~ 64.4 hp/l
Performance
0 to 100 km/h 13.3 sec.
(~ 0 to 62 mph)
Top speed 168 km/h
~ 104 mph
Weight-to-power ratio
16.1 kg/kW
11.7 kg/PS
~ 12.0 kg/hp
Chassis & Suspension
Front
Transverse control arm
Spring strut
Transverse stabilizer
Rear
Torsion beam trailing arm axle
Coil spring
Power steering serial
Front brakes Disc brakes, inner-vented
Rear brakes Drum brakes
Tyre dimensions 175/65 R 14 T
Fuel consumption
Recommended fuel Premium unleaded, 95 RON
Ø-Consumption 5.7 l/100 km
~ 41.26 mpg
CO2 emissions 136.8 CO2 g/km
Reach ~ 789 km
~ 490 miles
Dimensions
Wheelbase 2489 mm (97.9 in)
Front track 1473 mm (57.9 in)
Rear track 1460 mm (57.4 in)
Overall length 3950 mm (155.5 in)
Overall width 1722 mm (67.7 in)
Overall height 1481 mm (58.3 in)
Weights
Unloaded curb weight 966 kg (2129 lbs)
Max. permissible 1490 kg (3284 lbs)
Payload 500 kg (1102 lbs)
Permitted trailer load, braked - kg (0 lbs)
Capacity
Cargo volume min. 295 l (10.4 ft³)
Cargo volume max. 979 l (34.5 ft³)
Tank capacity 45 l (11.8 gal.US)
Bodystyle Hatchback
Doors 3,5
Seating capacity 5
Powertrain
Cylinders 4
75 cu.in.
82 PS
~ 80 hp
@ 5800 rpm
Charger None
Max. Torque
114 Nm
84 lbs ft
@ 4200 rpm
Manual gearbox 5
ratio
48.3 kW/l
66.0 PS/l
~ 64.4 hp/l
Performance
(~ 0 to 62 mph)
Top speed 168 km/h
~ 104 mph
16.1 kg/kW
11.7 kg/PS
~ 12.0 kg/hp
Front
Spring strut
Rear
Coil spring
Fuel consumption
~ 41.26 mpg
Reach ~ 789 km
~ 490 miles
Dimensions
Weights
Capacity
